Bimmerfest - BMW Forums
-   E39 (1997 - 2003) (http://www.bimmerfest.com/forums/forumdisplay.php?f=103)
-   -   How Do You Remove The Headlight Lens ?? (http://www.bimmerfest.com/forums/showthread.php?t=216632)
toddmack 07-09-2007 07:53 AM
Does any one know how to remove just the lens?:dunno:
dboy11 07-09-2007 07:56 AM
I believe that this is a sealed unit so I don't think just the lens can come off....here is a link to the removal of the whole unit
http://www.bmwtips.com/
Waveho 07-09-2007 08:54 AM
Some folks here have advocated baking the whole unit in an oven to liquefy the glue that holds it together. I think it's less hassle to just get another set on ebay....
bimmerd00d 07-09-2007 09:20 AM
Ehhh, on every E39 light i've seen it's just a matter of releasing the 5 brittle plastic clips and the lens pops right off. I'd be careful with them, you WILL break the top and bottom ones.
glocati 07-09-2007 09:44 AM
On the 97-00, there is no need for the oven/heating treatment. 4 bolts hold the whole assembly in, and as bimmerdOOd notes, there are 5 plastic clip that hold the 2 halves together. release those and carefully pry the front outer lense off. You then have access to the inner glass lenses which are held on by 2 metal slide on clips. Actually the whole removal is really easy, but do watchout for those clips. i was actually able to do it without breaking any of them, so it is possible.
dboy11 07-09-2007 09:47 AM
Once you have the lens off is there something that you need to re-seal it back on....mine is dirty from the inside and I have wanted for some time to clean them up
glocati 07-09-2007 10:17 AM
No, they just snap back together. I have not had any issues at all with internal moisture/dirt. you could run a small bead of sealant around the outside the two halves if you wanted.
When i had the glass lenses out, i cleaned a hazy film that had built up over the years off. and that really made a differnece as well.
here's a thread that shows a pic of the cleaned inner glass lenses... http://www.bimmerfest.com/forums/sho...m+install+pics
toddmack 07-09-2007 11:27 AM
that looks damn... good... the reason why i am asking i am installing ccfl angel eyes today/tonight and i just wanted an idea of how hard it was to actually to take off.
i will definatley be careful of those clips though.... i think i might heat them with a blow dryer first..to be a bit more safe...
glocati 07-09-2007 11:36 AM
Wow, cool. yea, as you can see, that's why i had mine out and apart as well.
PM if any Q's come up and i may be able to shed some light, as i have done 2 of the Predator Chromium CCFL installs now.
toddmack 07-09-2007 11:39 AM
thanks ... i will keep you posted.
question should i use a silicone to seal any wires?
glocati 07-09-2007 01:54 PM
i used clear RTV silicon to adhere the rings to the innerglass, and then a small dob where i routed the AE ring wires out of the rear of the black housings. I also had some heat shrink tubing laying around, and just for "wire management" use that to keep things tidy as i installed the wiring.
