HVAC blower question
We just picked up our '88 535i, and the blower doesn't function unless the A/C button is depressed. All the fan speeds work fine when the A/C is on, but nothing when just the heat is on. Does anyone have any idea what might be the cause of this?
Thanks in advance! |
Welcome to the wonderful world of the e28 featuring TWO fans! The one right above the shifter is for the A/C and when the heat is on the one below the wipers (accesible from the engine compartment) turns on. They are never both on at the same time. On this matter as Hugh1850 stated, cold or outside air only comes out of the center vents and heats only comes out of the top and bottom vents.
Good Luck! |
| All times are GMT -7. The time now is 05:04 AM. |
