Headlight Lens Renewal?
Just wondering can you purchase headlight lenses separately. Mine are looking fairly aged. I've been searching and all I keep finding is the entire headlight units. my car is a 2001 E39 facelifted model. All I want are a pair of lenes. Any help greatly appriciated.:)
have you tried polishing first?
or polishing with brake fluid?, if you getting rid of them, give it a go |
no the 2001 doesnt come seperate...:(
yep if you want new lenses on the 2001+ headlights you have to buy the entire headlight.
o well, thanks for the heads up. i can stop looking now. does brake fluid work sounds a bit messy.
Brake Fluid is a bad idea anywhere near PAINT!
I would try wet sanding first.
Plenty of people do it. I've done it, and it worked great. Note that the following DIYs are for the old 1996-2000 style headlights (which is what mine were), but plastic is plastic and I didn't even follow those DIYs, I followed one for a VW. Also, note that the DIYs state to remove the headlights, but I did mine whilst on the car, no problems at all: http://forums.bimmerforums.com/forum...d.php?t=930893 http://www.bimmerfest.com/forums/sho...d.php?t=261628 A general DIY, courtesy of VWvortex forums: http://forums.vwvortex.com/zerothread?id=2485084 |
pics before, during, after: http://img216.imageshack.us/img216/1282/1002196xm6.jpg http://img147.imageshack.us/img147/7862/1002205lv4.jpg http://img216.imageshack.us/img216/6420/1002215gv1.jpg |
Yep I've looked everywhere for facelifted lenses. They don't exist. Still very impressive work there Jon. A slight improvement ;)
Jonmcc, how long did it take for you to do that?
another tip: while wet sanding the best method (IMO) is to run the water over the lights, take the stream of water away and sand the lights until you see a milky white substance developing, then rinse them. eventually, the milky white stuff with not develop and you will know to move on to the next higher grit sandpaper. someone else told me that and it proved true for me too! |
I'm with jonmcc and pjb. I recently "rehabbed" my lenses last weekend. They weren't hazy, but there were a few surface dings that bugged me especially when the lights were on. Personally, I went from 600 to 1000 to 2000 grit sandpaper and finished it off with Meguiar's Plastx polish. The results were great. The lens surface is super smooth and the nicks and dings are non-existent. I do plan on going over it again by hand with the polish. (I initially hit it with the mini powerball) There are some hairline scratches that I notice only when the lights are on. (I may be a little ocd on this one, but aren't a lot of us) Save yourself some bucks and spend an hour or so on polishing instead of replacing! Just my .02!
| All times are GMT -7. The time now is 09:44 PM. |
