Bimmerfest - BMW Forums
-   E39 M5 (1998-2003) (http://www.bimmerfest.com/forums/forumdisplay.php?f=109)
-   -   M5 performance questions? (http://www.bimmerfest.com/forums/showthread.php?t=499524)
CTE39M5 11-17-2010 09:53 AM
alright everybody, i had a 97 540i.. and on friday i bought a 00 M5. right away i love the more power...but i need more. i have a friend whose doing dinan software on the car tomorrow. looking for anything, any ideas it doesnt matter...so lets here what youve got.
pics coming soon.
03BeastCharmer 11-18-2010 11:41 AM
More than 400hp?? You aren't going to get a measurable amount of additional hp without forced induction. I got intake and exhaust for the sound, did it add power? A little. Do I think I can feel the difference on the street? Not really.
If you just moved to 400Hp and you are already not satisfied, I don't know if you would be happy once you got to 500hp.
Aijay's X5 12-09-2010 05:29 PM
If you need more, buy an E60 M5 or an M6. Not sure they feel faster though.
dalekressin 12-09-2010 05:34 PM
More cost is not exactly better performance.
bimmernut1 12-15-2010 10:33 PM
Absolutly correct. You need to consider several things rather than just additional power.
I've attached a link showing the path that many M5 owners are taking; an ESS supercharger. It gets you to around 550 HP dependent on the one you pick. However, there are several things recommended before you add the SC. First freshen up your engine if it is high mileage; install larger clutch, some are even replacing their rod bearings which seem to be a wear item in the e39 if run at high revs or if the car has been chipped. There are several threads on the ESS superchargers in use.
As Dalekressin says it's not just the power; so if you haven't upgraded the suspension, I'd do that as well. Some also go with Stoptech brakes but you don't have to do this unless you're really going to push the 550 HP. Lastly, get rid of the cheap rear sway bar brackets that crack from the stock torque. Do a search for Beastpower sway bar brackets.
Anyway, here's the link.
http://www.esstuning.com/categories/...252dSeries/M5/
Stuka 12-16-2010 12:02 AM
A 2000? The MAF is probably shot.
Use the secret menu and see if you can get close to 140 liter/hour number. If not, there's your problem.
ak2002m5 01-02-2011 02:24 PM
03BeastCharmer,
just got my 2002 M5. I am new to used car. I have a 2008 550, but really like to try the M5 (manual). What type of intake and exhaust did you change? How much did you spend? I am looking for information on how to fix up my M5 alittle. Thanks.
Stuka 01-02-2011 03:11 PM
Originally Posted by ak2002m5 (Post 5737833)
03BeastCharmer,
Fahrschule = better bang for the buck than intake and exhaust.
03BeastCharmer 01-03-2011 01:36 PM
03BeastCharmer,
I have Dinan products. I got the exhaust during one of their sales years ago, and I got the intake used from a guy who was upgrading to an Dinan S3 supercharger, which doesn't use the same intake, so I got that for less than half price. Unless you get a smoking deal like I did, I wouldn't recommended getting an intake. For the pure sound I'd do an exhaust and chip again, and would recommend that.
If your suspension is old, replacement with aftermarket will help improve the handling, and make it feel a little lighter on it's feet.
ak2002m5 01-07-2011 08:00 AM
Thanks !
Thanks !! I am looking for a new suspension now.
bricas45 01-07-2011 08:04 AM
Do the headers you'll get measurable gains.
pcasey06 01-08-2011 07:54 PM
pics coming soon.
do suspension to handle the extra power.
then spray the sh*t outta it.
150 wet shot. hahahha
maybe a 75 shot.
