Bimmerfest - BMW Forums
-   E90/E91/E92/E93 (2006 - 2013) (http://www.bimmerfest.com/forums/forumdisplay.php?f=99)
-   -   TPMS Inactive missing or bad RDC Trigger (http://www.bimmerfest.com/forums/showthread.php?t=608109)
jcmcgrath 03-16-2012 04:22 PM
My 2007 335i e93 was missing an RDC Trigger on the right front after an accident ripped out the wheel well. All that remained were three wires to the device. The pinning is as follows.
Brown / White wire goes to pin 1
Black / White wire goes to pin 2
Gray / White wire goes to pin 3.
Parts
36236771042 RDC Trigger
61138365356 Universal Socket (1 needed)
61130005199 Electrical Contact Wire (White) 0.2-0.5 mm (3 needed)
61130006665 Electrical Contact Wire Bushing Contact 0.75 mm (not needed)
I used wire crimps to connect the wires and wrapped it all in black electrical tape.
After researching the internet, below are the Error Code related to this missing RDC Trigger.
604E Tire Pressure Control-system all tires
604F FL Transmission channel (usually means replace RDC Trigger)
6050 FR Transmission channel (usually means replace RDC Trigger)
6051 RL Transmission channel (usually means replace RDC Trigger)
6052 RR Transmission channel (usually means replace RDC Trigger)
Other Codes
6054 FL Wheel Electric
6055 FR Wheel Electric
6056 RL Wheel Electric
6057 RR Wheel Electric
DSXMachina 03-16-2012 07:22 PM
So...what is your question?
(free bounce from the bottom)
jose gamboa 10-02-2012 07:05 PM
location for rdc trigger unit
jose gamboa 10-02-2012 07:16 PM
hel
lo bimmerfest bmw community, happy to be a new member
