Bimmerfest - BMW Forums
-   X5 E53 (1999 - 2006) (http://www.bimmerfest.com/forums/forumdisplay.php?f=22)
-   -   Digital cluster problem (http://www.bimmerfest.com/forums/showthread.php?t=635437)
DEEMAC 07-26-2012 06:02 AM
I have a 2002 x5 3.0i and my digital readings on my cluster i cant read it also on my radio how do i fix this problem n e suggestions
tmvE39/E53/Z32 07-26-2012 08:36 AM
Search for "dead pixel" The problem is bad contacts between the signal ribbon and the display. You have 3 options:
1. You can try BMWNA for a "Good Will" repair. If you're a regular customer to your local BMW $tealers, they might offer 100% part and you cover the labor of the installation. In my case, they only offer 50% since I have never bring my BMWs to the $tealer for service before. It came out to about $600 with labor. So I went with option 3.
2. There are companies/individuals such as VODO Repair, germanautotech ... offer the repair service
http://forums.bimmerforums.com/forum....php?t=1871104
3. Bought the ribbon and replace it yourself if you're handy. It's a meticulous work that also require drilling holes in the cluster under the gauge. There are DIYs on the web.
GL
