Bimmerfest - BMW Forums
-   7 Series - E65 / E66 (2002 - 2008) (http://www.bimmerfest.com/forums/forumdisplay.php?f=126)
-   -   How do I connect the fiber optic loop to bypass the L7 amp? (http://www.bimmerfest.com/forums/showthread.php?t=642376)
bondheli 08-28-2012 06:20 PM
I purchased an additional loop and the "adapter", but neither are compatible with the connector that goes to the L7 amp.
JimmyW 08-29-2012 02:34 PM
There are two connectors on the L7; a larger rectangular sliding connector which is power and a smaller square connector which is what you need to bypass. The part actually going into the L7 is an adapter of sorts so you need to pull out the smaller two wire connector and fit it into your MOST bypasser.
bondheli 08-29-2012 06:15 PM
Ah, that was it, thanks a lot.
deiontroy 08-29-2012 07:55 PM
Can you bypass the L7 and still have sound?
bondheli 08-30-2012 11:46 AM
Yes but only in the front speakers. No sub either.
deiontroy 08-30-2012 01:42 PM
Ok Yeah I'm trying to get the subs to play
mo0107 01-22-2013 05:18 PM
Can you get you subs to play if you instal a most bus to stop the back doors from crackling and hissing
