Bimmerfest - BMW Forums
-   E60 / E61 (2004 - 2010) (http://www.bimmerfest.com/forums/forumdisplay.php?f=104)
-   -   Average Tyre Life (http://www.bimmerfest.com/forums/showthread.php?t=646502)
kskane 09-18-2012 05:28 AM
Average Tyre Life
I know this is a vague question, but say if you have mix of city and highway driving, what is the normal average minimum and maximum tyre life you guys have seen on your E60's? Please contribute min, max, tyre make and model.
1. 25000
2. 30000
3. 35000
4. 40000
5. 45000
6. 50000
Thanks.
pcy 09-18-2012 07:06 AM
It can vary significantly depending on the tire and type of driving. Aggressive driving [and not rotating the tires] will lead to more trips to tire store.
phlfly 09-18-2012 07:18 AM
I will never rotate tires it's not helping to longer life, it's making you pay more and for almost same tire life span.(you may getting extra 5,000 miles at most) That's what american consumer doesn't know, it's myth. It's cheaper just to replace two tires then all at same time.
It's scam by tire manufactures.
HPIA4v2 09-18-2012 07:18 AM
I'd say depends on the tires as well, some all season has very soft compound and wear faster (less mileage). but in general terms around 30k-miles, I don't like driving with semi-bald tires in Seattle area (it rains 8-month out of the year here, I mean 8-straight months total!)
hooch999 09-18-2012 11:42 AM
1. 25000
2. 30000
3. 35000
4. 40000
5. 45000
6. 50000
Thanks.
My all-season Michelin Pilot AS rears lasted just 15K on my 550i, fronts would be probably in 20-22K area, but I replaced all 4 with summer Bridgestone Potenzas - hard to tell yet what mileage I get, but ride became substantially harsher.
kskane 10-09-2012 02:10 AM
Has anyone had the problem where the front tyre's are wearing off from inside faster than the outside. I have had two changes of tyre's and wheel alignment was done on both sets of tire, but the front one keeps wearing off from inside. Is there something else wrong?
phlfly 10-09-2012 05:32 AM
I have same thing, even BMW dealer did already three times wheel alignment. I guess it's sport packg aftermath. The car sits lower so heavy weight from V8 make wheels worn this way.
hooch999 10-09-2012 07:11 AM
Check your control arms.
kskane 10-09-2012 04:51 PM
I am sorry but I don't know much on these, what should I check on the control arm? Are you referring to the bush, other than the bush what else can I check on a metal rod?
Thanks.
luilui41 10-09-2012 08:26 PM
Staggered Continental DWS on my 550, about 20-25k for the front and maybe 10-12k for the rear
phlfly 10-10-2012 05:20 AM
This is really low, do u race on them?
I have same set up fronts (Bridgestone) around 30,000-35,000 and rear (Yokohama Advin S4) now is 14,000 miles right on half of life, I guess I can get another 12,000.
kskane 10-10-2012 05:35 AM
Guys, any help is welcome. Apart from control arm bushes, is there anything else I should for the above problem? Tyres are due soon, so I need to know how to stop the uneven inside wear on the front.
luilui41 10-10-2012 06:28 PM
On the front ones I can probably get another 5000 or so, but my rear ones go bad fast, specially since they come with a negative camber the inside of my tires are gone before the outside reach even half life
phlfly 10-10-2012 07:59 PM
I do 3-5 psi higher then on door sticker.
kskane 05-02-2014 01:12 AM
Old thread, but its time for new tyres again. Anyone used Hankook tyre and know they are good?
javvy 05-02-2014 05:45 AM
I just installed Khomo Escta PA13.....they have rebate going on and they are nice.....best bang for your buck provide you find em in your size....I bought em from threaddepot.com.....if that helps..
javvy
maxxym 05-02-2014 06:37 AM
I had those Khomo tires on my e39. Worst tire ever. After a while, they became so loud that it sounded like I was driving in a lifted 4x4 with snow tires on.
Maini 05-02-2014 06:00 PM
My original Goodyear RSA laster 45K miles. I have a AWD car and I rotate and balance tires every 6K miles for free at America's tire or Discount Tire.
Since this is a AWD car my set up is all wheels and tires exact same set up (not staggered). My tires last because I rotate them and that is recommended.
Why does BMW have staggered set up?? what is the real advantage?? I see that on Mercs too.. but Toyota, lexus, Acura, Nissan infiniti all have straight set ups.. why the difference??
kskane 05-02-2014 07:59 PM
javvy
Thanks, would be good to know how long they last. KU36 are quieter tyre compared to KU31's, so I guess you like them :) so far.
Maxxym, do you know which Kumho's you had? KU22/KU31?
I hear Michelin part owns the Hankook, so was wondering.
javvy 05-05-2014 04:37 AM
So far I like the Kumho's...I guess they behave differently of different cars...I bought em cause I read a great positive review on tyrerack and that reviewer had the same exact car as mine a 530xi....plus the price was perfect.....plus I dont drive 100 miles every day....so far they are quite grippy and I suer have pushed them around and they handle perfectly....not sure how they will fair out after a couple of thousand miles on em...
Javvy
