Bimmerfest - BMW Forums
-   E60 / E61 (2004 - 2010) (http://www.bimmerfest.com/forums/forumdisplay.php?f=104)
-   -   2004 BMW 545i dash light problem (http://www.bimmerfest.com/forums/showthread.php?t=647383)
luisp813 09-22-2012 12:52 AM
i got a 2004 545i sport package 6 speed manual and i start driving and out of nowhere the traction control,ABS,Brake,DTc light turns on and sometimes the tv will go out.If i let go of the gas or step in the clutch it has like a hit/jerk to it its weird i just want to know if anyone knows the problem or came across something similar to this
luisp813 09-22-2012 11:51 AM
can anybody help me out with this?
jim165 09-22-2012 12:14 PM
Go to AutoZone and have your battery an alternator checked. Sounds battery-related
Kalil147 09-22-2012 02:10 PM
Ohhh buddy. Its the alternator. I had the exact same experience. I bought the alternator from ebay, its the same one as OEM. BMW uses a company called Valeo. Check your battery first, the alternator will act up after it heats up. So when you get it checked, they will most likely tell you it is ok.
luisp813 09-22-2012 05:06 PM
i just put a brand new battery on it so it must be the alternator thanks everyone i appreciate it alot
