Bimmerfest - BMW Forums
-   7 Series - E65 / E66 (2002 - 2008) (http://www.bimmerfest.com/forums/forumdisplay.php?f=126)
-   -   Dashsoft Drivers?? (http://www.bimmerfest.com/forums/showthread.php?t=649104)
crombo97 09-30-2012 05:37 PM
Dashsoft Drivers??
Can anyone please email me the drivers for Dashsoft.
Ive changed laptops and i cannot find the disc that came with the 4in1
Thanks in advance!!!!!!!:thumbup:
bmautosports@gmail.com
crombo97 10-01-2012 01:50 AM
Ace to the rescue
he just email me the drivers
Thanks heaps!!!!
745iguy 10-01-2012 07:07 AM
I could never get my dashsoft to work, always fails to communicate :dunno:
wjjklj 10-01-2012 02:20 PM
Sounds like your COM port is wrong. Go into control panel on windows and check this under devices.
sirstopher 10-01-2012 02:29 PM
Anyone have 64 bit drivers for windows 7?????? Mine are 32 bit and will not work.
I do have virtual machine and xp so I may go that route.
wjjklj 10-01-2012 02:31 PM
I didn't think you could run it on Windows 7. I run mine on Vista and older acre laptop.
wjjklj 10-01-2012 02:32 PM
Acer Laptop
sirstopher 10-01-2012 04:08 PM
Finding it out, no problems as the car will be in the ship for the next week with repairs.
Rebuilding the top end.
745iguy 10-01-2012 05:29 PM
Maybe its because my laptop is win7 32 bit? :dunno: Inpa winkfp NCS all work for me (just cannot communicate with the KOMBO or MMI), Carsoft, Dashsoft, Progman, GT1 do not even with a virtual machine :thumbdwn:
sirstopher 10-01-2012 07:15 PM
I'm just going to be truthfull here, I hear all this great stuff about dashsoft, get the package, not fucn instructions I move cd to HD and plug in cable, I get errors on USB.
I am just goi g back to INPA. Anyone want a useless cable
wjjklj 10-01-2012 07:54 PM
I am out of town right now with work but will look at my device settings on the Dashsoft when I get home. I had trouble at first and I agree there are no instructions. I ended up getting it to work by messing with the device settings and making sure the COM port was set on Com1.
I have more issues getting INPA setup. I have tried twice now and cannot get it to work. The Dashsoft is more user friendly in my opinion. I'll help you get Dashsoft running. Can you help me with INPA?
sirstopher 10-01-2012 08:03 PM
Took me 2 days with INPA, with someone else flipping the switches. I will just go to using NCS as dashsoft I thought was sooooooooo easy.
Where is the coding list, what the hell does what?
There is no way I am just going to start changing values without knowing what it does???????
Someone please show me the light here?
Are you all just plugging in codes to see what it does till you get what you want?
Is there a list? I see that SJ had a excel sheet where is it.?
Thanks BTW
wjjklj 10-01-2012 08:41 PM
I really use Dashsoft to check and clear codes. The only programming I have done is for the digital speedo.
They make another one for the E46 that I use on my sons 330ci. It just has boxes that you check to turn on programming features and is super easy to use.
Who is the INPA master on here .? I really need help setting it up . Not sure if something is wrong with my program files.
sirstopher 10-01-2012 08:46 PM
INPA is the same, check and remove codes. NCS is how you code.
Several members here use both.
Pkathee helped me, CCCP can help you, shoot him a pm
sirstopher 10-01-2012 08:47 PM
Paper can too, just need to ask.
Btw, I am speaking for both of them, they may tell you to FO.
LuvThis7 10-05-2012 11:35 AM
Does have anyone have dashsoft 2.1 - im trying to code my MMI - but i need software vs 2.1 i have 2.0
