Bimmerfest - BMW Forums
-   E46 (1999 - 2006) (http://www.bimmerfest.com/forums/forumdisplay.php?f=98)
-   -   What my problem??? (http://www.bimmerfest.com/forums/showthread.php?t=649733)
LPenna 10-03-2012 06:05 PM
What my problem???
Can someone please help me find my issue with this check engine light.
I have a 2001 325i e46. I fail smog and had these part changed and I still get the check engine light after 80 miles of resetting the light. i change the MAF with the air tube and clean the ICV which did not look very bad after having 112k on the car. I also change all 4 O2 sensors. Change of spark plugs also.
I have peake code reader and only two code come up saying E3 and E4 O2 sensor adaptation limit cyl # 1-3 and 4-6.............
What is my issue......please help me....:mad:
harryhchen 10-03-2012 11:32 PM
so what are codes?
scarede46er 10-04-2012 12:09 AM
I have peake code reader and only two code come up saying E3 and E4 O2 sensor adaptation limit cyl # 1-3 and 4-6............."
CPBIII 10-04-2012 06:46 AM
take your car to a local parts store that will read the OBDII codes. Better if they can provide the BMW codes which alot of readers will do.
LPenna 10-04-2012 09:39 AM
Problem in California is that store ain't allow to do that any more. I was surprise also. Should I just buy a new code reader??
harryhchen 10-04-2012 09:44 AM
You can get a ODBII reader for around $20 from Amazon. Here is what I have:
http://www.amazon.com/Autel-MaxiScan...s=ODBII+reader
LPenna 10-04-2012 12:26 PM
What the difference between this one and the ones that are bigger and little more expensive. Does those one give more info, Or does it do the same job?
CPBIII 10-04-2012 01:56 PM
Check the specifications and find one that will provide manufacturer specific codes. Probably won't be the $20.00 plan.
chansta 10-04-2012 09:36 PM
those are adaptation codes. most likely your car is running lean due to a vacuum leak. probably cvv needs to be changed.
