Bimmerfest - BMW Forums
-   E46 (1999 - 2006) (http://www.bimmerfest.com/forums/forumdisplay.php?f=98)
-   -   cluster wont she highbeams are on? (http://www.bimmerfest.com/forums/showthread.php?t=649978)
ikinkk 10-04-2012 08:11 PM
So recently my cluster failed, then started working again, changed the fuses for it and what not to try and save some money, and it worked!
But here is my problem.. When I switch to high beams it will not show it on the cluster in its little area. I did just change light bulbs today also. Anyone have an idea as to why it is not showing that they are on?
new_kid 10-05-2012 06:16 AM
Use a test light... or Ohm meter to check for closed or open circuit. Bulb isn't everything.
