Bimmerfest - BMW Forums
-   7 Series - E65 / E66 (2002 - 2008) (http://www.bimmerfest.com/forums/forumdisplay.php?f=126)
-   -   trans failure (http://www.bimmerfest.com/forums/showthread.php?t=650804)
ctjames3 10-09-2012 09:45 AM
trans failure
I've got a 2006 750li with 123,000 and when I try to accelerate to a passing gear, I get a trans failure alarm. When i stop, cut off the car and restart the alarm clears. Would someone have an idea as to what is going on and what the solution is? thanks
Mr.Class 10-09-2012 10:01 AM
I have the same problem..... I just order the guibo, I'm hoping that this will fix everything ... I will report back on Friday .. I already changed the spark plugs coils valve covers trans fluid & pan & did a hard reset... So we will see
J-303 10-09-2012 12:21 PM
Sealing sleeve, adaptor need to be replaced most likely. It's for the Mechatronics unit. Transmission housing. Look up Mechatronics on this forum. I t happened to me a year ago. Good luck! Let me know what you find. Parts if you can do yourself are cheap. If you send me your email I can send you my work order.
J-303 10-09-2012 12:22 PM
ctjames3 10-09-2012 01:52 PM
tranny
Thanks for the info, will be looking into getting it fixed ASAP.
ctjames3 10-09-2012 01:53 PM
tranny
"I just order the guibo,"
What does that mean.
J-303 10-09-2012 03:32 PM
Haha. I have no idea. If the dealer fixes it it costs around 900.00 pastors are about 300 with new transmission fluid. Since your down that way anyway you should change fluid.
Parts I meant.
Mr.Class 10-09-2012 03:44 PM
I know what your talking about with mechatronics on my 02 745 LI they told me it had to be changed but I never did it.. But after changing the transmission fluid no the pan it stopped doing it & drive like a brand new car... As for my 2005 745LI I know it's the Guibo because I can feel its coming from the back... & I know the person who had the car before me just did transmission pan & filter @ a Indy & I'm certain they put enough trani fluid.. So I'm gonna have it topped up and a hard reset & change the Guibo ... I got the car two weeks ago & drove it straight to my Indy they changed all kinds after all this I would have spent damn near 3 grand.. But it's gonna be worth every penny I love this car
theckj 10-09-2012 07:03 PM
Hey ctjames - go to California transmission supply. http://www.thectsc.com/. They will hook you up with all you need. A new mechatronics sleeve ran me about 12 bucks. They have troubleshooting information etc.
ctjames3 10-10-2012 05:44 AM
tranny
hey, thanks all, I will go to california trans supply and have the parts and fluids shipped Thanks again, the dealer in New orleans was no help at all.
