Bimmerfest - BMW Forums
-   7 Series - E65 / E66 (2002 - 2008) (http://www.bimmerfest.com/forums/forumdisplay.php?f=126)
-   -   Radiator (http://www.bimmerfest.com/forums/showthread.php?t=651633)
wjjklj 10-13-2012 02:38 PM
Radiator
5 Attachment(s)
Well I started my project by replacing the alternator. Then I figured why not just go ahead and replace the water pump. Then why not the belts and hoses. Today I noticed corrosion on my radiator. So I am ordering that.
I am attaching some pics so chime in. What time or mileage is expected to replace radiator? It was not leaking but does have corrosion on the inside and outside.
I can get a OEM BEHR model for $250 or a Nissens unit for $150. Any thoughts? Anyone ever use Nissens? Thanks.
sirstopher 10-13-2012 05:14 PM
What water pump did you get? BMW?
What alternator? Bosch?
You will always pay more for OEM parts, but in the end you will know that they work.
wjjklj 10-13-2012 08:46 PM
I bought a GRAF water pump with the metal impeller versus the OEM plastic one. The alternator was a new not rebuilt Valeo unit which is exactly what was the original unit was. I leaning towards the BEHR radiator even though it is $100 more than the Nissens unit.
wjjklj 10-13-2012 08:47 PM
1 Attachment(s)
wjjklj 10-14-2012 12:05 PM
Anyone else ever replace radiator on e65 or e66? Anybody use Nissens?
1bad540 10-14-2012 06:59 PM
rad looks ok to me, but i guess while your in there draining fluids.
wilk187 10-14-2012 07:14 PM
i replaced the radiator in my e38 at 85k....they (e38) had a tendency to crack near the neck, but i haven't heard any issues with the e65 radiator...that being said, you'll probably be fine either way. but for less than $100 difference i'd go Behr
wjjklj 10-14-2012 08:24 PM
No it is actually corroded on the sides.....hard to see from the pics. The corrosion is on the inside too.
wjjklj 10-14-2012 08:25 PM
I bought the Nissens unit. It states that it cools better than the BEHR and has the same warranty. We will see how it lasts.
