Bimmerfest - BMW Forums
-   E39 (1997 - 2003) (http://www.bimmerfest.com/forums/forumdisplay.php?f=103)
-   -   Help!!!!! Knock sensor and fuel trim codes (http://www.bimmerfest.com/forums/showthread.php?t=662008)
Talh3 12-03-2012 04:10 PM
I installed a new thermostat last week, last night I finished replacing my valley pan , oil seperator and back hoses. Now I am having codes from the peak meter that weren't there before!! They are 06 , d4 knock sensor cylinder 5-6 , 06, 1b fuel trim ol additive cylinder 1-4, 06 , 23 fuel trim ol additive cylinder 5-8. Someone please help! Also will it hurt to drive the car with these codes? It seems to be running good. I am also still bleeding the system . Thanks , Tal.
edjack 12-03-2012 05:24 PM
You may have disturbed the left front knock sensor. They are kind of touchy, esp if you unbolted them and placed them back in the wrong position.
You DID replace the intake manifold gaskets, right?
Talh3 12-03-2012 06:49 PM
I'm almost positive we did, I'll have to check with my roommate he did most of the work. Will it hurt to drive like this?
Talh3 12-03-2012 08:16 PM
Yes we did replace the manifold gaskets. We didn't unbolt the knock sensors and pluged them back in . What do you recommend? Also thank you for the reply, I really appreciate your help!!!! Will it hurt to drive? Ta
Hanks Tal.
