Bimmerfest - BMW Forums
-   E39 (1997 - 2003) (http://www.bimmerfest.com/forums/forumdisplay.php?f=103)
-   -   Speedometer stopped working for BMW 520i 2001 (http://www.bimmerfest.com/forums/showthread.php?t=667119)
mikepariva 12-30-2012 04:31 PM
Speedometer stopped working for BMW 520i 2001 reg
tim330i 12-31-2012 08:00 AM
Welcome to Bimmerfest. I moved your post over to the E39 forum, which is the chassis code for your BMW. Take a look around this forum for speedo issues or one of our members will reply with some ideas on what might be the issue.
Good luck,
Tim
johnstern 12-31-2012 08:40 AM
The LR ABS wheel speed sensor provides the input signal to the speedo. Could be a failed sensor or a bad ABS Control unit. Could also be the speedo head which would be a very different problem-not the usual fault.
If you go to the Wiki section of this forum (top tool bar at the far right) and go to the ABS Control Unit section, you will find Bluebee's "place to start" thread which will help with your diagnosis.
bluebee 01-01-2013 05:10 AM
You can learn how to test the wheel speed sensors here:
- E39 ABS DIY
