How to Reset My Inspection light
I hope this is the right forum. Can some tell me how to reset State Inspection error on my 2007 525xi?Thanks, :eeps:
I have the same problem on my 88 e28, it has the inspection light on and a red and yellow light under it.
Can anyone pls help me how to change my bmwx528i center brake ,,please thanks
If you do an instrument cluster test that usually solves the problem.
If you don't know how to do the test see the following YouTubes: (Most of the models follow a similar procedure for instrument cluster test) http://www.youtube.com/watch?v=MUr_eGCJ7wU http://www.youtube.com/watch?v=ToIMATmD4Uw |
1 Attachment(s)
Hey guys I was looking to reset my inspection light too but I didn't find any answer here however I did the dash computer test as the video posted and there is a light came on and I won't go away does anyone knows what is that ?
Attachment 366750 |
Hey man I found the service indicator on YouTube anyway what will u do is press the RIGHT button and then put the key in the ignition and turn it to the 1ST position and don't release it until it says RESET then press on the SAME button again and hold until the light flashes then click once and u r good to go thanks for bringing it up and I still have problem with my dashboard light that it came on I don't know what is wrong with my car now
| All times are GMT -7. The time now is 12:22 PM. |
