Bimmerfest - BMW Forums
-   F10 / F11 (2011 - 2016) (http://www.bimmerfest.com/forums/forumdisplay.php?f=141)
-   -   Tire change before lease end Question (http://www.bimmerfest.com/forums/showthread.php?t=691236)
bfv 04-21-2013 04:43 PM
I have 32 K miles:D on the car and 11 months to go on 12K/36 mo lease:eek:. I will be extending the current lease for at least 6 months with BMWNA. I want to do second ED in summer so will extend the lease that expires in March 2014 to August 2014.
By that time, the car will have have around 40-42 K miles on it and likely require new tires upon lease return. I wonder if I should change the tires now and use (around 10K miles) a portion of new tires before returning it!!:dunno:
Need opinion re: approach to this situation. ALSO, Do I have to replace tires with same company or any company with same specs (i.e: all-season, run flats, 17" )
Thanks.
jjsC6 04-21-2013 05:22 PM
I had a similar situation on an Infiniti a few years ago. I tried to milk the original tires to the end but didn't make it. I wished I had changed them out earlier. It all depends on how much tread you have left.
rawmn 04-21-2013 05:49 PM
You can buy used ones from a junk yard or somewhere else way cheaper and return the vehicle to the dealer ;)
Nison 04-21-2013 08:49 PM
they only have to be run flat with same size
miamiboyca 04-21-2013 09:31 PM
How is the tread currently? If you think it they are adequate for turn in, then get a new set of non-run flats now... and put the run flats back on before you turn it in. You can either sell or reuse the non RFT.
spadae2 04-21-2013 10:13 PM
If you are buying a new BMW, run them into the ground if you can. If BMW CPOs your car they will put new tires on it. Also, I have had very good luck with my dealer when buying a new BMW in the same situation, I told them I will buy new run flat junks {they must must have them} on to SELL the car, they buy me a set of non-RFTs for my new car when it arrives. RFTs are the worst. And if you are not getting a new BMW... well do what most dealers do to you...
bfv 05-16-2013 05:03 PM
The tread currently is about 4/32". I plan to drive another 10-12K miles.
Also, will putting non RFT from some company affect warranty in any way?
