Bimmerfest - BMW Forums
-   F10 / F11 (2011 - 2016) (http://www.bimmerfest.com/forums/forumdisplay.php?f=141)
-   -   Burger N63 (http://www.bimmerfest.com/forums/showthread.php?t=720320)
evanswan 09-05-2013 08:46 PM
Burger N63
Just Installed Today !
Wasn't too hard. Took an hour. Noticed it let the rpm's rev a bit higher. It is faster for sure. Feels like it just goes through the gears to fast though. I will spend more time driving it tomorrow.
Does anyone know what the motor HP is with the tune. Looks like its 412 at the wheels.
MoldCAD 09-06-2013 01:42 AM
Try this: http://www.mk5cortinaestate.co.uk/calculator4.php - you will be happy :)
dunderhi 09-06-2013 05:08 AM
HP at the crank using HP at the wheels should only be calculated as a very, very, very, rough estimate due to the general innaccuracy and errors found with rolling dynos. For example Mustang dynos typically report 10-15% less WHP than DynoJets, so a DynoJet may only need 10% drivetrain loss factor to get to crank HP while a Mustang could need 25% factor, but in general dynos results for even a single brand of dyno have been different by 10% or more. Some of this variation could very well be in manufacturing differences itself, since every N63 will not have exactly the same HP as it rolls out of the factory. It is my understanding (read - no proof) that the advertised HP, especially for German brands, represents a minimum HP spec that would pass all of their quality control checks. So German cars tend to dyno higher than say, US cars, for an advertised HP.
BTW, congrats on your BMS. I'm curious about the rpms, since I would have thought that parameter would not have changed. What's your new max?
Alan L. 09-06-2013 06:29 AM
RPMs shouldn't change. Sending a false single to the tmap sensors wouldn't magically do that. (I'm sure the burger camp would love to be able to do it though)
kthankzbye 09-06-2013 04:56 PM
Burger N63
Here's a tip. Make sure you zip tie the harness to the two strut bars. I just tucked mine away and yesterday, I had drive train malfunction. When I opened the hood, the harness got chopped in half by the fan. Luckily, after putting it back together, it still works. Phew.
Splurged 09-07-2013 07:01 AM
Im pretty sure thing will void our warranties if found, have you guys tried to undue the changes back to factory?
badblack550xi 09-07-2013 07:04 AM
same exact happened to me! i used 2 clips and attached to one of the hoses now its not going anywhere.
it takes 5 minutes to take it off
Splurged 09-07-2013 07:10 AM
I'm thinking about ordering one today, you're still happy with the tune? Haven't noticed any technical problems or engine lights turning since the installation?
M4XBMW7 09-07-2013 07:32 AM
I stalled mine at 3400 miles and now 9500 miles and couldn't be happier, for such a cheap tune and yet well known and reiable you'd be a fool not to got with BMS. And did I mention that the results are superb :)
