Bimmerfest - BMW Forums - View Single Post - Noise at cold startup
Old 01-28-2005, 08:11 AM
al_r al_r is offline
Mein Auto: '96 328i
That is your secondary air pump, 'injects' fresh air into the exhaust manifold at start up time till the ECU shuts it off - strictly emissions related. If the pump fails, you'll get a CEL/code indicating 'not enough volume' in the front or rear engine banks.
If you decide to replace it, also replace the valve it feeds on the exhaust manifold.
