Bimmerfest - BMW Forums - View Single Post - Help: sluggish shifting
Old 03-11-2005, 07:56 AM
DZeckhausen's Avatar
DZeckhausen DZeckhausen is offline
Send a message via AIM to DZeckhausen
Mein Auto: 2012 BMW F30 328i 8-Speed
Originally Posted by bluetree211
needs new transmission fluid?
New transmission fluid may help, but I'm suspicious that the problem crept up over such a short period of time.
Try replacing the "lifetime" tranny fluid with two bottles of Royal Purple Synchromax. You'll need just slightly less than two bottles. Use a 17mm 6-point socket and a long breaker bar to get the drain and fill plugs off. (Not in that order, of course!) And you'll need a small fluid transfer pump such as the kind you can pick up at Pep Boys or NAPA for $6. Fill the tranny until fluid overflows and starts to run down the side of the case.
While you're under the car, inspect the linkage between the bottom of your shift lever and the top of the tranny.
Hopefully, the new fluid will cure what ails your car. If not, then you may have some clutch issues cropping up. Keep your fingers crossed!
Dave Zeckhausen
Owner, Zeckhausen Racing
2015 BMW X1 xDrive28i M Sport
2012 BMW F30 328i Luxury Line 8-Speed
StopTech 4-wheel big brake upgrade
2001 BMW E39 540i 6-Speed (Traded-in for F30)
CDV deleted
