Bimmerfest - BMW Forums - View Single Post - "Fixed" my idling problem: 1987 325
Old 04-08-2005, 05:50 PM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
idle stuff
buy a haynes or bentley repair manual (20-40 bucks) and get out your voltometer and check the ohm's and voltage resistance in these things throttle position switch ,air flow meter,and then check your feul pressure and your fuel pressure regulator . Oh and try running your car at night looking at the plug wires this way you can see if a wire is grounding to the motor and some bosch plat +4's would be nice, i havn't found an rough idle yet that a $6.99 spark plug couldn't fix.good luck
p.s.if all else fails check compression
