gas smell
I've read in these threads that this is a common problem. I believe you remove the rear wheel by the filler cap and then the plastic wheel well liner. Above that you will find an expansion tank that is connected to a "T" that usually goes bad. Do some searches in different e30 forums for detailed instructions
