Bimmerfest - BMW Forums - View Single Post - light change/repair onboard computer
Old 05-04-2005, 09:57 PM
elroy elroy is offline
Mikey
Mein Auto: 1991 325i
If you have the OBC that calculates gas milage and all that, then what you need is the OBC light bar. www.bavauto.com sells it for about $25, your local dealer will be somewhere around that price too. You should change the keypad bulb while you're at it, as it's only like $1.
I would type a guide up but it's already been done time and time again. Basically you'll be coming at it from the right side of the console (passenger kick area) -- OBC is held in by 4 screws. Remove the screws, pull the OBC, change the light bar, and then put everything back together.
Here's a writeup:
http://www.unofficialbmw.com/repair_....html#fixlight
