Thread: 2000 bmw m5
Old 06-07-2005, 08:03 PM
01Byte's Avatar
01Byte 01Byte is offline
Pastafarian Extraordinair
Mein Auto: 335d
Originally Posted by jeshie7
i bought a 2000 bmw m5 may, 28th 2005 it only had 24000 miles on, it was a perfect car and was rarely driven now june 7th with 26,000 miles my clutch gave out completley and now im gettin my clutch and flywheel replaced at bmw for $2400. but its kind of odd for a clutch to blow out at 26000 miles anyone had a simliar problem?
I'm looking to get a M5 and have been doing some research. I can offer you this...
First, the clutch on the M5 is the weakpoint of the drivetrain. It does not stand up against abuse. If the driver before you tracked the car regularly (or drove it like he did), then the clutch might suffer premature failure.
Second, you could save yourself about $1,000 dollars if you did the work at an independant mechanic. $2400 seems high.
Anyway, look at it this way, you will have a true Beast with a new clutch that if treated right will last a long time.
Congrats on the car and hopefully this is the only glitch you'll find.
May we be blessed by His noodly appendage and His almighty sauciness.
