Old 07-24-2005, 04:40 PM
AsianImage's Avatar
AsianImage AsianImage is offline
aka Turd Ferguson
Send a message via AIM to AsianImage
Mein Auto: Excellence
Replacing regular bulbs with LED bulbs
I was thinking of replacing my signal and reverse lights with LED bulbs. The kind that are simple plug in replace ments like these:
I heard that if I use these bulbs, my check brake light warning will go on because the LEDs are drawing a much lower current...and since the BMW sensors read the current and not the bulb I would get a warning and need load resistors and such.
Is that true? If so I guess I will skip these and just get some Japanese PIAA bulbs instead. After reading about the HID reverse lights, I am just going to pick up some hyper whites and call it a day...
Thanks for any info.
“If I tell you I'm good, you would probably think I'm boasting, If I tell you I'm no good, You know I'm lying.” — Bruce Lee
