Bimmerfest - BMW Forums - View Single Post - Headlight switch dash light
Old 10-01-2005, 03:56 AM
my_e36 my_e36 is offline
Mein Auto: e36 323i coupe
Remove lower driver dash (the one under the steering wheel, 4 screws total, 2 of them are on the underside), remove the know by pulling straight out (might want to use some double sided tape for leverage), then there's a hex-shape nut holding the switch onto the dash, remove that and the whole unit drop out from bottom. Then you can replace the bulb.
Installation is reverse of removal.
