Well, with the replaced alternator it runs. I got it home but it ran hot again. This time I see the guage go up to red when I get it in the driveway. Was a little low on coolant as a result of replacing the expansion tank and refilling the system. However, I filled it back up and let it run in the driveway with the hood up only to find that the fan isn't powering on at all. Auxiliary fan switch maybe? Any way you know I can check that? My biggest problem is the closest dealer is 45 miles away.
