Bimmerfest - BMW Forums - View Single Post - Alpina B10 BiTurbo
Old 01-18-2006, 04:05 PM
pickles pickles is offline
Mein Auto: bmw
Turbo
If you dont use the incorrect grades and bores you are in big trouble ,i know this because i have done this myself ,not on a bmw but still all the same, what will happen is your rings will cook and they will loose all there spring ,then step by step it goes down the line, all turbo engines are heat treated , your bonnet will be up so much your engine will have a sun tan, take this advise my youg jedi ,look deep inside yourself , i'm sure you will make the right choice.
