Bimmerfest - BMW Forums - View Single Post - Oil Change S54 Wheres the Drain Plug?
Old 01-21-2006, 02:57 PM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
Originally Posted by MPOWEROH
Okay. I own a 2.8 Z3 and can eaily identify the location of the oil drain plug. When I lifted my new 01 M coupe with the s54 motor it all looks different. For starters the bottom of the motor is covered with a plastic shield. There is no 17 mm drain plug visible (as indicated by my Bently manual). I do see a allen head socket plug next to a round cover (approx 3" in diamieter). Can some one advise as to the location of the drain plug. Is it necessary to remove the plastic covers? Removal looks like a lot of work just to drain the oil.
There is a plastic door that swings down exposing it. Many of us have removed the plastic under body cover for the reason you mentioned.
I initially modified the car for jacking before I removed it. The second pic shows the oil drain plug access cover.
