03-30-2006, 06:02 AM
Mein Auto: 03 M3 Coupe
Originally Posted by tom @ eas
Yes, the ice>Link Plus will use the 3-pin (ibus) and 6-pin adapter (audio signal).
I am asking because for those who's experiencing the problem, this might be caused by a loose connection on the adapter. I don't have the ICE-Link and I've experienced the similar problem with all the interior lighting goes off (the turn signal and light would still work but just nothing shows in the cluster), controls on steering wheel stopped working, etc. Later on I found out this is caused by a bad I-bus connection and pin point to the back of the CD player. Some how the connector to the back of the factory CD player is loose though it seems it's got a tight and solid connection. I remember I hit a big pothole the day before this had occured and it must have bump the connector loose some how. A simple replug fix the problem.
For those who's having the problem, I suggest you to unplug all the connector and re-plug it again and see if it will fix any loose connection.
