Old 12-01-2002, 01:02 PM
Randy Forbes's Avatar
Randy Forbes Randy Forbes is offline
Investigative Tinkerer
Mein Auto: ///Motorized Vehicles
Re: Are the parts the same for the M Coupe?
Originally posted by caylan
When I do my MCoupe will the parts# be the same?
If you have an M Coupe, the upper guide is different (and handed).
Preliminary check (you should verify) is that your guide bearing #'s are:
LH 31 33 2 092 897
RH 31 33 2 092 898
Again, you should verify these numbers for your application.
BTW, unless you want to replace your upper guide bearing, your existing ones can be reused.
Randy Forbes
1957 Austin-Healey 100/6 Wine Red
1961 McCulloch R1 go-kart Screaming Yellow
1999///M Rdstr Cosmos Black Eurosport Twinscrew S/C
1999///M Coupe Estoril Blue Eurosport Twinscrew S/C
2001///M Rdstr Steel Gray
2011 X5 35i Sport Deep Sea Blue/Cinnamon
