Re: Bulb Replacement Help
Originally posted by bob lindquist
The left side of my heat/ac control panel light is out. I pulled the radio and using a mirror found one bulb E 106 (its sort of in the middle) I think I see E105 way down under the flap control but how do I get e105 out? I guess they twist out but I can barely touch the bottom one. No one said working inside consoles was easy but this has me stopped. HELP
On the lower left and right side of the radio opening there are screws that hold the HVAC unit in place. Once you have the screws out, there are two tabs at the top of the HVAC assembly. Pull up on these and it releases the HVAC unit. This might help.
