Just be careful.............clean fluid and filter is usually a good thing but with high mileage trannies you can dislodge a lot of crap inside with new fluid and end up causing tranny failure...........never use any of the tranny shop flush machines..........best to drop pan, clean out crap, change filter and install new SYNTHETIC fluid..........run for 3-5k and change again to get all the old fluid out.........you may have to do it 3-4 times to be completely set with new fluid.........change filter again on what you feel is the final change......cheap insurance.......
Dinan Stage 3 E31 850 Twin Turbo (one of 4)
625 HP 660 ft lbs torque on 93 pump gas @14 psi
