Rattling sound
I had a rattling sound from the rear passenger side suspension, so I put it up on jack stands and put it in gear. It was the brake pad on the inside of the rotor, one of the clips holding the pad had come loose and was giving "wiggle" room. Didn't hurt the rotor, just went and bought a set of pads for the rear and problem solved.
To give you an idea of what it sounded like, if you put a small bolt into a beer bottle and shook it around, it would sound very similar.
