Bimmerfest - BMW Forums - View Single Post - 2007-2010 X3 Automatic Transmission Problem Master Thread!
Old 02-16-2008, 10:26 PM
el-sea el-sea is offline
Mein Auto: 2007 x3
different dealerships?
Originally Posted by Andrew*Debbie View Post
An X3 with a manual transmission. Our is great.
Did you ever try taking your car to another dealer? I've seen several cases where the cars were not diagnosed or repaired correctly.
Who knows BMW continues to release updates. The most recent one made things worse and was pulled. Presumably, they will fix it and release it again.
I think part of the problem is that there is more than one problem. If you read through the posts, not all cars have the same symptoms.
I have tried 3 different dealerships. The last was the most respectful and truly the most helpful. They even seemed concern until it came down to the last straw BMW NA...I went back and forth from dealership to BMW NA. They each said well the other says there's nothing wrong and nothing they can do. There is no problem if it doesn't happen when the tech drives it. BMWNA even sent a specialist out to the dealer. Didn't happen when he drove it so......My word and my children and grandchildren and friends word means nothing. Like someone here said "we are all hallucinating" or have ESP...(that one I have to Anni up to though). Is anyone else's surging forward after you take your foot off of the gas? One comment I am curious about a note from the tech in some paperwork .. "the tack hit 7000 in sport drive". Is it suppose to do that? I am not that knowledgeable.
