02-19-2008, 03:16 AM
Mein Auto: 2001 BMW 330i
Originally Posted by bmwm3coupe
Like Torquewrench stated, the key is to follow the "correct" fluid check/procedure for your tranny. The temp range for mine was between 30-50 deg C, preferably closer to 30 to get the most fluid in, and of course, the car has to be level, and running to do this check.
Will
I hear ya, guys. I am curious as to how you checked the temp though. Did you use a thermometer?
What I am really asking about is if you guys heard a change in the sound of your car, at idle, when you changed the ATF. I am pretty sure I did everything correctly. I didn't have a thermometer though. The pan was warm to the touch, but not hot.
