Bimmerfest - BMW Forums - View Single Post - **Z4** DIY Guides (Post links here)
Old 02-24-2008, 11:10 AM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
Z4 Exterior mirror glass instructions
Following compliments of Palantirion:
First the mirrors. Step 1 is to slide this tab to the left to unlock the mirror (major PITA ):
The mirror pulls off with its retaining clip and then you unscrew three screws to remove the motor. Also disconnect the two wires and connector:
Another view, also showing how to tilt the mirror so you can unscrew the screw holding the plastic cover in place:
Take another four screws out and release two small tabs inside the mirror housing and you can slide it off.
