What indication did you guys experience that prompted you to check for leak. Better yet: if the valve cover seal is leaking what indication one can experience. Here's my situation. I replace the TPS and clean the ICV. the engine light still comes on off and on and a steady light. The idles when I come to stop light or sign then it will flactuate. I can tell the ICV is working and is clean because when you first start the car the rpm will be high for a second or two then it drops to proper rpm. Also, when the car is idling and flactuates then pull the tube from the valve cover. the front tube idle will be smooth but high. Can someone tell me what that indicates aside from idling high.
