03-14-2008, 02:37 PM
Mein Auto: 2002 330i w/ SportPackage
Originally Posted by NorthStar7
3) It appears the manual is incorrect as it pertains to the iPod config switches. It says "It is recommended that you leave these switches in the default (OFF/ON) position." However, the default position (as my model was shipped) is OFF/OFF. If I want the Locked/DICE mode, should I leave the default OR should the switches be Off/ON? Earlier in this thread scottgbp posed the same question. Tom's response was "the manual is correct". I can't see how the manual can be correct since the unit is shipped off/off and that configuration is not mentioned as a supported configuration.
The older instructions do have an error in them, this has been corrected. The kits remain unchanged in the process.
Tom, I'm still a bit confused with your reply. Exactly what is the error? And what is the correct dip switch configuration to use in the "Locked Mode"?
Is it Scheme A or Scheme B as follows?
Scheme A
Car Config. Switches
1) off
2) off
Ipod Config. Switches
1) off
2) off
Scheme B
1) off
2) off
1) off
2) on
