Old 03-26-2008, 07:22 PM
What does the tangental cut in rotor edge indicate?
Thanks for the Final Stage Unit (FSU) "hedgehog" advice (aka porcupine resistor); I'll also look at the fuse deeply behind the glove box according to that article. My fan isn't "posessed" so much as it's just not working ... so I'm not sure if the FSU is the culprit but it seems a commonly failed part based on that article that it might be the cause of my fan stopping all of a sudden and not something I did when I cursed at that horrid air-cleaner box setup!
Back on topic for the BMW brakes DIY, can someone edify me as to why there is a "slit" in the side of the old and new rotors?
This slit seems, upon first glance, to be a wear limit grooved into a tangental slice of the rotor; but, the fact that my clearly worn (as measured by the "inchometer") front rotors still had much metal above the slice, makes me wonder.
Is the slice to indicate a horribly gone you're-gonna-die thickness of the rotor? If not, what does the rotor slice indicate?
