03-29-2008, 07:11 PM
Mein Auto: 1985 318i BMW
another one
well here is one i found today...got me a can of carb cleaner and sprayed around like everyone else has done before...i was getting the same symtoms idle fluctuates when in neutral...like i said started spraying around the engine looking for that vacuum leak and just could not find anything at all the vacuum lines that i could see....then just for the sake of it...i sprayed at the bottom of the fuel injectors and lo and behold i had a reaction...found out that the o rings on my fuel injectors were deterioted and was leaking there...changed the o rings and finally got to adjust and time the engine so that it did on rev up and down...hope this help some one out too...
