Old 08-17-2008, 10:37 AM
Orient330iNYC's Avatar
Flying monkey herder
Mein Auto: Daihatsu Terrios
Originally Posted by ed914 View Post
Orient:
Thanks for the research on this topic. I have same vehicle as you and am also interested in this solution.
Was at a local dealer and noticed a 2008 535xiT service loaner (non ZSP, all-season tires). It had a T135/80R17 102M compact spare just like the one you discovered from the 550i. Didn't feel right about pulling it out to check the rim size :-) , so don't know if it is the 4BX17 ET:18 that you found fits our 335s.
Tried researching 535xiT parts for spare rim size, but Tischer site doesn't have that vehicle. Can you suggest another source to find if the 535xiT emergency rim would fit our cars?
Cheers, ED
i just checked, all the E60s use the same tire and wheel. the retrofit kit application covers all E60s.
are you looking for just the rim? warning being, the reason i got the whole kit was that the tire to go on the rim is quite hard to find.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
