Bimmerfest - BMW Forums - View Single Post - E90/E91/E92/E93 OEM Spare Tire source
Old 10-09-2008, 08:27 PM
classicBMW classicBMW is offline
Mein Auto: '06 325
Originally Posted by Orient330iNYC View Post
you have an 06, which uses the indirect FTM method. i'm not sure if you can/should reinit the tpm system when using the donut.
when i drove around with it all weekend, i had the angry flat tire warning message on, as the spare tire does not have a pressure sensor in it ( post 3/07 E90s have sensor based direct pressure monitoring)
Thanks. Assuming I don't ever use the spare, the 4 standard tires won't screw up the TPM, will it???
