Old 10-12-2008, 07:12 PM
tfjoneser tfjoneser is offline
Mein Auto: 740il
I had the same issue with wipers not working. pulled the cover on the fuse/relay box on the back left hand corner of engine compatment (looking from the front of car) and found that the relay had gotten wet, water had gotten into this box and caused the relay to short out. I bought a new relay and replaced and still didnt work! I pulled out the connector that the relay sits in and found that a small wire had broken off of its connector. I repaired the wire by soldering it back on the connector replaced the relay and all worked great.
