Bimmerfest - BMW Forums - View Single Post - Z3 HVAC bulb replacement
Old 11-09-2008, 12:05 PM
robrez robrez is offline
Mein Auto: Topaz Blue 3.0i Z3 Coupe
Thanks for the info. One more tip for that pesky left side HVAC bulb, on M models, if you remove your middle gauge, you'll be able to see the left side bulb holder through the hole in the 10 o'clock position. You can reach through the hole and pull it if you have super strong fingertips or you can use a needle nose pliers. This is assuming, you can reach through the stereo opening to turn the collar behind the gauge in order to first remove the gauge.
