Bimmerfest - BMW Forums - View Single Post - E46 M3 will not crank, start
Old 11-22-2008, 07:48 PM
cell21633 cell21633 is offline
Black Ops
Mein Auto: E46 M3
Originally Posted by Bruce View Post
I won't insult your intelligence and ask if you have the clutch depressed....
A fuse is either bad or it is not...it won't be intermittently good (or bad) to make it a sometime start issue.
Have you pulled the codes?
Have you tried a different key?
Might try replacing the main and start relays, but I would pull the codes first before throwing unnessecary money at the problem.
harharhar.. this is my second stickshift-driven vehicle.. of course it is depressed.. even gave it a few good mashings to make sure a sensor wasn't sticking
i have not yet pulled codes. trying to avoid the dealership and trying to diagnose on my own.. better to learn that way. i have tried different keys. doesn't make a difference.
but where would i find the relevant relays? i just got the car back in march '08 and haven't been able to poke around in the engine compartment other than doing oil changes.
