Common Maintenance Issues
I thought it might be helpful if we had a thread handy that mentioned the common problem areas of the e36 /M. Things to look for when searching for a new car and things to keep in mind as the miles go by (in fact, much of this list is normal maintenance). Here's a list off the top of my head:
1) Rear shock mounts
2) Rear Trailing Arm Bushings (RTABS)
3) Water pump (they seem to last about 40k miles even with the ss impellers, but 95 - mid 97 /Ms had a stock plastic impeller that failed routinely)
4) Transmission mounts (to avoid mis-shifts)
5) Shocks (oem seem to last about 40k miles)
6) Radiator (hose fittings crack - about 60k miles?)
7) Thermostat housing
8) Vanos failures seem to be fairly common
9) The undercariage panel seems to routinely fall off (and can be replaced with an aftermarket metal piece that stays)
Anyone think of anything else?
