Old 06-04-2003, 11:21 AM
rwg rwg is offline
Mein Auto: '14 A4
Originally posted by zcasavant
Mine is difficult to shift into gear. Is there a TSB or something regarding the shifting difficulty?
Thanks.
There is a TSB for the shifting difficulty. If your car has difficulty getting into gear after it warms up, they will replace some pins and seals in the transmission. Apparently, the pins would catch on something and prevent you from going into gear. However, this is sort of like a catch - if you just have notchy gates, getting the TSB repair might not help.
Also, when I had it done, the TSB was not in the dealer's computer. Brecht seems to go the extra mile - they called BMW's helpline, found out about it, and had it faxed to them.
