Old 02-01-2009, 09:08 PM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
Z4-M NA Passenger side motor mount bracket problem
http://www.bimmerfest.com/forums/sho...d.php?t=233491
http://www.bimmerfest.com/forums/sho...d.php?t=247988
http://www.bimmerfest.com/forums/sho...d.php?t=272236
http://www.bimmerfest.com/forums/sho...d.php?t=294159
http://www.bimmerfest.com/forums/sho...0962&highlight
http://www.bimmerfest.com/forums/sho....php?p=4067789
If you want to use BMW stuff MotorSport Z4 uses the following:
http://www.bimmerfest.com/forums/sho...ght=motorsport
Screw 07 11 9 913 653 $0.47r
Screw 07 11 9 913 673 $0.62r
Washer 07 11 9 903 078 $0.35r
Bulletin:
Angle torque:
This is used on the connecting rod bolts and other things.
You torque the screw and then turn it degrees mentioned in the TIS torque area for what your doing.
http://www.unofficialbmw.com/all/too...le_torque.html
Retail is $191.37 now.
Motor mount bracket screws:
I had the front reinforcement plate out to clean the power steering fluid.
Good time to do the motor bracket screws.
Will do the drivers side when I remove the air collector.
I used the Motorsport 10.9 screws and washers.
Torqued all four at 24Nm with the following Sears tools.
Torque:
